h23 question is the knock sensor or temp sensor or what?
Old May 17, 2003 | 01:33 PM
LudaKris's Avatar
Default h23 question is the knock sensor or temp sensor or what?
I'm replacing the head on my h23 and when i pulled it off I cracked a sensor on the backside of the block. The sensor is approx in the middle of the 2 and 3 pistons real close to the top of the block is this knock sensor or what? and where can I get and how much do they cost? Thanks for all your input
92 lude si
Old May 17, 2003 | 04:03 PM
Sir_Phobos's Avatar
Default Re: h23 question is the knock sensor or temp sensor or what? (LudaKris)
i believe you broke your knock sensor, is it throwing a code?
Old May 17, 2003 | 04:36 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudaKris &raquo;</TD></TR><TR><TD CLASS="quote">I'm replacing the head on my h23 and when i pulled it off I cracked a sensor on the backside of the block. The sensor is approx in the middle of the 2 and 3 pistons real close to the top of the block is this knock sensor or what? and where can I get and how much do they cost? Thanks for all your input
92 lude si </TD></TR></TABLE>
How many wires go to it?
Old May 17, 2003 | 06:23 PM
LudaKris's Avatar
Default Re: h23 question is the knock sensor or temp sensor or what? (Chiovnidca)
I will have to double check but I think two wires. I have not put the car back together as of yet because I know I need to replace this guy first...
Old May 17, 2003 | 06:40 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudaKris &raquo;</TD></TR><TR><TD CLASS="quote">I will have to double check but I think two wires. I have not put the car back together as of yet because I know I need to replace this guy first... </TD></TR></TABLE>
If it has 2 wires, it's the knock sensor. The new one should be torqued to 23 lb/ft.
Old May 17, 2003 | 06:49 PM
LudaKris's Avatar
is this a dealer only item?
Old May 17, 2003 | 07:13 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudaKris &raquo;</TD></TR><TR><TD CLASS="quote">is this a dealer only item?
*shrug* I don't know.
sobeman81
Nov 30, 2008 07:17 AM
LudaKris
Jun 1, 2003 01:38 AM
noslude93
Mar 18, 2003 08:23 PM
