h22a no reverse ???????
Old Aug 7, 2003 | 05:43 PM
vx_hatch's Avatar
Default h22a no reverse ???????
just put in 95 h22a into my civic and it wont go into reverse, but goes into 1st-5th gear fine.... i thought it was the cables but wont go manually with out cables hooked up. need to get it fixed...and i bought the swap from hmotorsonline.....thanks
Old Aug 7, 2003 | 06:34 PM
quik1's Avatar
Default Re: h22a no reverse ??????? (vx_hatch)
What cables are you talking about? Does it go into gear and the car not move or it won't even go into the reverse gear position? Are there any grinding noises or anything like that?
Old Aug 7, 2003 | 08:15 PM
whatVTEC's Avatar
Default Re: h22a no reverse ??????? (quik1)
My friend had the same problem in his 99 Prelude. But it was an intermitent problem. Sometimes reverse would work and sometimes it wouldn't.
Old Aug 7, 2003 | 08:30 PM
poison's Avatar
What mount kit are you using?
Old Aug 8, 2003 | 11:26 AM
vx_hatch's Avatar
Default Re: h22a no reverse ??????? (poison)
i am using hasport mounts and i took the drivers side mount off so the cables are not hitting anything and it wont grind or anything won't go in at all....thanks
Old Aug 8, 2003 | 04:46 PM
vx_hatch's Avatar
oops i mean i took the passenger side mount off
Old Aug 13, 2003 | 07:27 PM
vx_hatch's Avatar
well fixed the problem and all i did was changed the tranny fluid with GM Synchromesh Transmission Fluid and it works great now....
Ammar.f
Mar 28, 2019 03:26 PM
flatline911
May 15, 2007 04:36 PM
hyspeed1
Apr 1, 2007 04:31 PM
hondaaccord94
May 2, 2005 08:53 AM
H22EKHATCH
May 1, 2005 09:44 PM
