h22 pistons
Old Feb 11, 2010 | 12:33 PM
wang92's Avatar
Default h22 pistons
ok so i got a problem
my little brother helped me rebuild my motor
and he took out the pistons and did not lable which one goes where
and i was wondering if the order matter? i know that the arrow points
toward the timing belt but i wasn't sure if the one that came out of cylinder #1
had to go back in the same place?
can anybody help me?
PLEASE AND THANK YOU
Old Feb 12, 2010 | 06:41 PM
Mikey3000's Avatar
Default Re: h22 pistons
you're screwed. are you replacing the rod bearings? i'd be more worried about the rod bearing clearances than the rings. did you replace the rings? are they stock pistons?
Old Feb 13, 2010 | 10:42 AM
Glock17's Avatar
Your not screwed dude, so if your going to rebuild it do it right or your going to be doing it again. Take it to a machine shop so they can hone and get the correct size bearing for you. While your at it order some ARP bolts for head and lower end such as the rods and main bolts. You are going to need to take the ARP's and motor to the shop. Once you get the parts back from the shop remember to plastic gauge the bearing to make sure it correct. Take your time and don't let your bother put it together doesn't sound like he know what he is doing.
TravisBiggie
Apr 10, 2013 08:21 AM
jprelude92
Apr 7, 2010 08:36 AM
seldon
Jun 15, 2008 06:39 PM
Yuleluder
Feb 15, 2006 05:14 AM
Fatty_1775
Dec 16, 2002 08:33 AM
