h22 crank
Old Aug 22, 2011 | 03:28 PM
dc4teg's Avatar
Default h22 crank
Ok I have to put my crank from my first h22 in my current h22 block. What Im wanting to know is are all the journals on each crank the same size? Is the only difference the block size? Im just trying to find out what color OEM Honda bearings I need to make my motor good. I need to get done asap. If anyone has any imput please let me know. I am not new to Honda.
Old Aug 22, 2011 | 05:41 PM
H2b-eghatch's Avatar
Default Re: h22 crank
obd1 has 50mm mains obd2 has 55mm
Old Aug 22, 2011 | 06:59 PM
civickiller's Avatar
has the crank been cut?
Old Aug 22, 2011 | 07:37 PM
KStuned's Avatar
No, not all of the journals are the same size.
Old Aug 23, 2011 | 11:24 AM
dc4teg's Avatar
No the crank hasnt been cut. Thats what I thought. What numbers on the crank do I use to get the proper code? I have 44444 on the block just need to know what I use on the crank. Also I am thinking about doing the balance shaft delete why I am at it. I have seen a lot of at home DIY but I dont think I want to try that way. Think I would rather do the expert kit.
Old Aug 25, 2011 | 09:18 AM
dc4teg's Avatar
If I use the code off my new h22a crank with the code on my other h22a block and go by the color I would assume that id be fine? Someone correct me if im wrong.
Old Aug 27, 2011 | 10:47 AM
dc4teg's Avatar
Bump I need to get back my car.
Old Aug 27, 2011 | 07:35 PM
no, you need the code from the block and crank your using
Old Aug 28, 2011 | 05:16 PM
dc4teg's Avatar
If I go by code for the rods its all green. Mains are lil bit confusing to me. The mains from number one go brown, brown, brown/blk, brown/blk, brown/blk. So on the brown/blk do I use half brown and half black or just pick one?
justnprsh07
Oct 6, 2011 06:57 PM
SiR-T
Apr 6, 2008 07:26 PM
jasondok
Sep 12, 2006 07:43 AM
