Guru's i need help, code 4
i took my motor out last year to freshen it up, and now its back in, and i got a code 4 (crank angle sensor), its a b16 w/ gsr head, obd1, p28 ecu, the only thing i changed was whoever did the swap before me used butt connectors on the 2-wire plug on the distributor
i soldered those ones, and now i get a code, the wires are in the right place
i also upgraded from a msd 6a to msd digital 6 plus,and added a blaster coil
now my friends have told me too:
1. flip the wires on the coil
2.new ignitor
3.pull the distributor, rotate, and re-install
do you have any suggestions? the main problem is there is no vtec,and it runs funny
thanks
2.new ignitor
thanks
DC2 Mang
Feb 23, 2006 05:58 PM
