GSR/Type-r Piston questions
If i run a GSR block and Type-R pistons...
What Head and what connecting rods should i run with it???
And what kind of compression do people get with the suggested set-ups??
Please no Zealautowerks links....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekek888 »</TD></TR><TR><TD CLASS="quote">you can run w/ur gsr head and rods if u want. u onlly have to remove a little bit on the piston end side of rods. any machine shop can do it.</TD></TR></TABLE>
I thought was only if you were putting type r pistons on b16/17 rods ?
the ls and the b16 both have the wider rods,that why alot of people like to put the b16 pistons on the ls rods,cause you dont do any machining. the type r will fit on the gsr with no machining and no clearance issues
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g hatch »</TD></TR><TR><TD CLASS="quote">the ls and the b16 both have the wider rods,that why alot of people like to put the b16 pistons on the ls rods,cause you dont do any machining. the type r will fit on the gsr with no machining and no clearance issues</TD></TR></TABLE>
http://www.importreview.com/d_1.8.html
look at the 11 one down. thats on jun stage 3's with a milled head. you can do it as long as your cams are degreed,your clearances are right,and you have a hell of a tuned.that one may be race gas i dont know but u can always get a thicker head gasket to get u in the range u want. alot of people dont like them cause theres not alot of room for error but they will make alot of power. its your motor do what u want
in the end its your motor if doing something a little different makes u happy go for it. just do it right. have all the clearances checked,cams degreed,and a great tune with hondata or something.
JDM_EK4_Coupe
10
Jun 29, 2007 12:54 PM
PnkRokCountryboy
17
Nov 20, 2005 04:08 PM
Thanks for your help thoose power numbers are swaying me more and more toward doing this....
