GSR suspension
Old May 31, 2003 | 12:19 PM
EK9kellen's Avatar
Default GSR suspension
Here is the deal I have 200 bones saved up for a full GS-R suspension that I want to put on my 97 civic hb. My problem is I dont know how hard this swap is going to be. Im not that car savy and this is my first honda. Have any of you guys done this swap before, how hard will it be to do? thanx
Old May 31, 2003 | 12:35 PM
Kataku2K3's Avatar
Default Re: GSR suspension (EK9kellen)
Full suspension as in hubs/brakes, etc.??? If so it's very straight forward, I would recommend upgrading the master cylinder to to that of a Teg but the Civic one will work fine... For the front pull part the suspension and just swap in the Teg knuckles... On the rear, it's easiest to pull the whole assembly off, then unbolt the hub... Swap in the Teg, and put it back on... When doing this I would also recommend having your car realigned, along with the camber and toe in/out... Good Luck and let me know if you need anything else... Peace
Old Jun 2, 2003 | 04:24 PM
Doogie Howser's Avatar
Default Re: GSR suspension (Kataku2K3)
whats the diffrence between civic front brakes and integra front brakes? how much bigger rotors, are there better calipers?
Old Jun 2, 2003 | 05:08 PM
dfoxengr's Avatar
sorry but you wont get much for 200$
tegra fronts are 11.2 i think and civics 10.8"?
tvman
May 4, 2006 10:15 PM
EGB18
Jul 13, 2004 11:47 AM
EG6FF
Mar 23, 2004 05:10 PM
jumpmann23
Jul 6, 2003 09:00 PM
greebler
Jan 10, 2003 05:57 PM
