GSR rod bearing question.
Old Feb 5, 2008 | 04:04 PM
blkb18's Avatar
Default GSR rod bearing question.
I am freshening up my b18c1 for my JRSC. I clearly see the stamp on the block for the main bearing sizes, and the letters coincide with the colors on the bearings. What is throwing me off is the number 3 stamped on all 4 of the rods. I thought this is the bearing #, but I can only read 2 or the 4 colors on the bearings and those two are different colors. Any help apprieciated.
Old Feb 5, 2008 | 04:34 PM
ekb16's Avatar
all 4 rods have 3 on them right? y are tryin to read the colors? all u need is the stamps on the rods, crank, block and u should be good to go
Old Feb 5, 2008 | 08:07 PM
IN VTEC's Avatar
Default Re: GSR rod bearing question. (blkb18)
The letters on the block match with the numbers on the crankshaft to give you the recommended bearing color for the mains.
The letters on the crankshaft pair with the numbers on the connecting rods to give you the recommended bearing color for the rods.
cjonescrx
10
Aug 2, 2012 04:41 AM
tremor86
Aug 14, 2007 09:13 AM
panchovilla760
Mar 2, 2007 09:26 PM
B pwr
Dec 27, 2002 11:57 AM
