GSR Redline Problem
Old May 1, 2007 | 10:25 AM
1kreationz401's Avatar
Default GSR Redline Problem
i just finish doing my swap, and for some reason, i never had a problem like this before, my first swap i did, i could take my rpm to 8200 no problem but with this swap it doesnt go pass 7000 rpm please help me out people.
Old May 1, 2007 | 10:56 AM
hatchling37's Avatar
Default Re: GSR Redline Problem (1kreationz401)
Wrong ECU?
Old May 1, 2007 | 12:35 PM
98or00gsr's Avatar
the ecu may be chipped from the previous owner for a smaller rpm range.. thats my guess.. hope it helps
Old May 1, 2007 | 12:37 PM
BEST1TUNING.COM's Avatar
Default Re: GSR Redline Problem (98or00gsr)
Does the cut at 7000 feel like a normal rev limit fuel cut?
Old May 1, 2007 | 07:08 PM
gibsanez's Avatar
and CEL?
Old May 1, 2007 | 07:11 PM
93supercoupe's Avatar
Default Re: GSR Redline Problem (gibsanez)
they will cut at 7000 when Vtec isnt hooked up right or working properly.
Check the oil
Old May 2, 2007 | 03:26 PM
once it gets to 7000 rpm, it cuts off, the ecu is correct, p72, swap it to another p72 same problem, im thinking it might be the rsx oil filter, its smaller, couple of guys i know use rsx oil filter to build dup faster oil pressure and for better response for vtec, but when vtec pops, **** pulls pretty good but suck when it redlines 7000 rpm. Did a new oil change too when swaped motor. imma switch out oil filter see if it helps.
mouses911
K Series
Jan 30, 2017 06:45 PM
Mason Fraser
Oct 7, 2012 05:37 AM
jdmaccord2k
Oct 8, 2008 06:10 AM
muhaMan
Apr 11, 2008 07:43 PM
jxj220z28
Feb 11, 2004 01:24 PM
