gsr intake manifold?
Old Mar 22, 2003 | 08:05 AM
dabomb's Avatar
Default gsr intake manifold?
i have a b18c1 and i'm using a chipped p28 and i know that the p28 is not capable of controlling the butterfly valve of the IM. so my question is which runners of the manifold am i using all the time???? the short ones or the long ones?
Old Mar 22, 2003 | 12:26 PM
Patch's Avatar
Default Re: gsr intake manifold? (dabomb)
Your secondaries are stuck open. This means you lose about 10 lb. ft. of torque on the low end.
Old Mar 22, 2003 | 02:00 PM
joe_bocc's Avatar
Default Re: gsr intake manifold? (CRX PAT)
Are you sure about that? I thought the butterflies would be stuck closed.
Well if i'm not wrong, the longer, upper runners are the ones your using.
Old Mar 22, 2003 | 02:55 PM
Patch's Avatar
Default Re: gsr intake manifold? (joe_bocc)
I'm not 100% sure, but I remember reading some threads about it a while back and thats what I thought they said.
Old Mar 22, 2003 | 04:50 PM
dabomb's Avatar
if you think that i'm losing low end torque then are you saying that i'm using the short runners all the time? If your right then whats the point of me getting a skunk2 IM if i am already using the short runners all the time? Isn't that why guys with gsr motors get the skunk2 IM?
Old Mar 22, 2003 | 05:03 PM
Luke J's Avatar
Shorter runners provide better airflow for top RPM-band power, but give up a little torque on the bottom end. Using shorter runners would move the powerband of the engine up, shifting the torque and horsepower curve. (hope that helps you)
-not sure about the stock gsr mani question
TheCrimsonGhost666
Jun 6, 2010 08:42 AM
lalocivic
May 27, 2010 07:56 AM
sonazty
Jan 29, 2010 05:51 PM
Kangolbrand
Mar 13, 2006 09:04 AM
lilxvtecxpwr
Jun 20, 2002 04:14 AM
