gsr head removing valves which tool
Old Oct 30, 2009 | 01:04 PM
Kr4nG's Avatar
Default gsr head removing valves which tool
okay i know how to remove the valves on my gsr head. the thing is i have 2 different tools and i cant get either one to work. does someone have any ideas on which tool works the best on a gsr head. dont say use a spring compressor tool cause i have two and they dont work.
Old Oct 30, 2009 | 02:11 PM
havok hybrid's Avatar
Default Re: gsr head removing valves which tool
You get a socket the same size as the retainer... you hit the deep end socket against the retainer.. and the keepers will just pop out. May take a couple of hits then you will see what it takes.
No special tools to remove them.. But you will need one to install them.
I use a snap on Over head cam valve tool. Its universal .. look it up if you need one.
i got mine for 119.00 Its a kit.
Old Oct 30, 2009 | 02:14 PM
projectTeG's Avatar
lol, i use a big c-clamp and a o2 sensor socket
Old Oct 30, 2009 | 03:36 PM
Kr4nG's Avatar
havnt thought about the o2 sensor socket. putting them on is the tricky part. any other tricks?
Old Oct 30, 2009 | 06:46 PM
bigD's Avatar
I like this one myself http://www.euroexportinc.com/product...ducts_id=44427
Old Oct 31, 2009 | 07:40 AM
sleepinonacreeper's Avatar
Originally Posted by bigD
i've used that tool also and it works very well
Old Oct 31, 2009 | 08:40 AM
KWayRacing's Avatar
A magnetized socket is perfect for keeping up with the keepers.
Old Oct 31, 2009 | 08:54 AM
dntnedvtec's Avatar
In the main forum, there is a DIY and a very detailed, picture on how to do your valves, valvestem seals. SEARCH!!! GL
here:
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2Ahow-%2A%2A%2A-install-valve-springs-valve-stem-seals-1604753/
Old Oct 31, 2009 | 09:49 AM
Kr4nG's Avatar
thanks a lot guys i ordered that tool looks like something i was trying to make but didnt work.
Old Nov 17, 2009 | 04:47 AM
Darrell Bs 10SecEG's Avatar
I use this common tool from Sears. http://www.sears.com/shc/s/p_10153_1...0070921x00003c
Old Nov 18, 2009 | 03:06 PM
96b18c's Avatar
Haha, same way I used to do it. First time I was taught to do it this way I remember being scared, but it works and you won't have to buy any extra tool.
Old Nov 19, 2009 | 03:05 AM
ctownintegra's Avatar
I also reccomend the euro export tool. I have the one for honda and Mitsubishi . Life would have sucked without them. You just bolt it to the head and take your time removing and installing everything. When putting the keepers back in, instead of using the magnet, use a dab of grease on the flat head end to hold the keepers, so when it is in place you give it a wiggle and it comes off easier than with a magnet.
Old Nov 19, 2009 | 01:09 PM
dntnedvtec's Avatar
Okay, what about for Non-Vtec motors, say, a p75 head(LS,GS)?
mannydhanju
Mar 2, 2009 07:13 PM
CRX89DX
13
Feb 13, 2009 06:49 PM
team 15
Apr 13, 2008 05:51 PM
j spec
May 14, 2006 02:54 PM
see_our_vtec
Sep 21, 2003 10:24 PM
