GSR diff. backlash
Old Jul 2, 2004 | 05:49 AM
deSigi's Avatar
Default GSR diff. backlash
Does the backlash of GSR differentials have a tendency to get out of spec? I'm getting some knocking whenever I let go of the clutch. The knocking happens in reverse as well.
Old Jul 2, 2004 | 09:47 AM
deSigi's Avatar
Default Re: GSR diff. backlash (blkDX)
Bump, anyone with experience with trannies?
Old Jul 2, 2004 | 06:18 PM
Sliced Beard's Avatar
Default Re: GSR diff. backlash (EKsleeper)
the differential gear can tend to get worn but if you have a knock noise i would put the blame on your input shaft splines being worn like these are....especially if you have a performance clutch and you like to "dump the clutch"
pics will be up momentarily.........
Old Jul 2, 2004 | 06:39 PM
Default Re: GSR diff. backlash (dirtyd463)
here is a photo
Old Jul 2, 2004 | 09:33 PM
TIRENECK's Avatar
the tip is worn out?
Old Jul 2, 2004 | 09:45 PM
Default Re: GSR diff. backlash (TIRENECK)
the picture does not show it very well but the splines are supposed to have a shape like this /^\ and they are worn to a shape like this /\ if that helps any
with the splines like that it gives the clutch the freedom (which will most likely have the same wear) to rotate back and forth a few degrees and will have a "clunk" sound
Old Jul 2, 2004 | 10:19 PM
z6's Avatar
z6
my z6 used to this when i put my new tires
Old Jul 5, 2004 | 01:38 PM
deSigi's Avatar
How bad is it to drive with an input shaft like this. If this is my problem that is. BTW do they sell friction plates with splines like this /\ or are they all like this /^\?
I checked it out again today and the engine shakes like mad when I release the clutch normally. The car doesn't really jerk forward or backwards too much. Most of the foce is absorbed by the engine mounts.If I release it slowly it doesn't do it.
Modified by EKsleeper at 5:54 PM 7/5/2004
Old Jul 14, 2004 | 06:56 AM
deSigi's Avatar
I am now 99% sure what the source of the problem is. I jacked up my car the other day, to check the free play in the wheels when the car was in gear. The only place where I noticed that there was a lot of play was the right side inner CV joint. It also made a metalic noise. I'm guessing it most likely must be that. I didn't hear any play coming from the clutch housing or the differential. The only place the noise is coming from is the CV axle.
I'll change it when I get my engine rebuilt and I'll let you know if I was right.
Old Jul 14, 2004 | 07:58 AM
Default Re: (deSigi)
if in fact your input shaft splines are worn you will have to buy a new friction plate/clutch and you wil need to get a new input shaft and have it installed if you are not capable of the install yourself
Old Jul 14, 2004 | 08:17 AM
deSigi's Avatar
Default Re: (dirtyd463)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtyd463 &raquo;</TD></TR><TR><TD CLASS="quote">if in fact your input shaft splines are worn you will have to buy a new friction plate/clutch and you wil need to get a new input shaft and have it installed if you are not capable of the install yourself</TD></TR></TABLE>
Yeah I know, but I noticed that all of the play that I have is due to the inner right side CV joint. So hopefully, that's all that I need to change.
Modified by deSigi at 9:58 PM 7/14/2004
Probot
Apr 18, 2007 07:00 AM
kihun_cha
Mar 22, 2007 05:16 PM
llozll
Dec 26, 2006 09:54 AM
EJ8VTEC
18
Jul 1, 2005 12:30 PM
Que
Jan 17, 2002 10:37 PM
