GS-R Fast Idle valve
Old Jan 28, 2003 | 09:56 AM
RacerMike's Avatar
Default GS-R Fast Idle valve
Is #8 in this picture the fast idle valve? I need to order one and I don't have my manual with me.
Any help is appreciated.
Mike
Old Jan 28, 2003 | 10:00 AM
Desslok's Avatar
Default Re: GS-R Fast Idle valve (RacerMike)
Yes. FYI, you can clean them sometimes if they are sticking.
Old Jan 28, 2003 | 10:22 AM
zilverz's Avatar
Mike
No .. that is the Idle Air Control Valve (IACV) you can take it off....spray it thuroughly and clean the screen with carb cleaner .... and replace the ring gasket ...
if you still have an idle problem .. you can try turning the Idle Air Screw on the TB clockwise
Old Jan 28, 2003 | 10:27 AM
RacerMike's Avatar
Default Re: GS-R Fast Idle valve (zilverz)
I'm not really sure this is the problem. The symptom is that I get differing idles at different times. It may idle at 1200 on one start, but after shutting off and restarting it may idle at 800. Whereever it idles, it idles steady, but its idle point is not consistent.
Ideas?
Mike
Old Jan 28, 2003 | 11:18 AM
speedymon's Avatar
Try cleaning it and see what happens. #8 is a picture of the IACV though.
Old Jan 28, 2003 | 11:37 AM
Kataku2K3's Avatar
Default Re: GS-R Fast Idle valve (speedymon)
I would also check the throttle plate.. Sometimes it can stick aswell... I've seen them clog up a lot more than IAC's... Peace
Old Jan 28, 2003 | 11:49 AM
zilverz's Avatar
If im not mistaken... from a cold start it is designed to idle a little higher than normal and then it gradually comes back down to what you have your idle set to by the Idle air screw....
i dont remimber why exactly ... but coolant flows throught the IACV.. maybe the cold coolant has to warm up ?
Old Jan 28, 2003 | 12:02 PM
Kataku2K3's Avatar
zilverz are you talkin about the FITV??? That's what does exactly as you are talking about.... while the motor is cold cold coolant flows through the FITV which keeps the valve in it opening bleeding air around the throttle plate therefore raising the idle a bit... As the coolant warms up the valve closes and the idle goes back down to the idle... At this point NO air should be getting bypassed the throttle plate... You are correct about the coolant flowing through the IAC and that is just not let it freeze in cold temps... If it freezes there is nothing to control you idle... Peace
Old Jan 28, 2003 | 12:56 PM
EE_Chris's Avatar
Default Re: GS-R Fast Idle valve (Kataku2K3)
If NO air was bypassed around the throttle blade, you would stall. There is however a screw affectionately called the "Idle Air Bypass Screw". This is used to set the Curb Idle Speed....which is what your motor idles at when the IACV has been unplugged. There is also a Throttle Blade Stop Screw, which is set from the factory to keep the butterfly from rounding out the throttle body bore. If you mess with this screw, you are messing with the TPS adjustment to.
Old Jan 28, 2003 | 01:48 PM
Kataku2K3's Avatar
Default Re: GS-R Fast Idle valve (EE_Chris)
My bad I should have specified, I meant through the FITV port in the TB.... And yes you are correct about the rest... As for the "throttle blade stop" screw there is also a limit to how much you can close it down, if you are trying to drop the idle so i really wouldn't mess with it... You close it down too much and it will stick like a bitch especially if you go from WOT to closed... Just kinda jams itself... Anyways sorry for the inconvenience Peace
Old Jan 29, 2003 | 06:54 AM
zilverz's Avatar
IF you have a SAFC or VAFC ... there is a Throttle Voltage reading ... to make sure the throttle plate is set correctly it needs to read .45volts with the pedal not pressed at all or im sure you can test it at the sensor as well .. .but my SAFC is HANDY !
Old Jan 29, 2003 | 08:13 AM
sgT's Avatar
sgT
It should be noted that late model integras, 96+ if im not mistaken, do not come with fast idle valves
Old Jan 29, 2003 | 08:49 AM
Nix_TEG's Avatar
I dont if thats your problem or not but but the Fast idle air valve is located under your throttle body , its upside down under neear the #13 bolt !!
I checked to see if a 98 LS mainfold had it and it did !!
I relaced the FIAV on my 90 TEG ( different mainfold) cause the idle was bouncing up and down until the car warmed up to temp.
23nesnes
Sep 22, 2009 10:21 AM
ryanhauk
May 20, 2009 06:42 PM
Junkyard2000
Oct 26, 2005 03:16 PM
sporkcrx
Nov 9, 2002 06:59 PM
