Grounding Kit ?
if you pay ~$100 bucks for pretty much 6-8 4-8 gauge ground cables, with terminals and pretty much a distribution block, i would say thats foolish. You can just buy wire, terminate it yourself and buy a block (which you don't even need). Personally, not worth it, as long as you have good grounds ( scrape paint to bear metal) and the flow of electrons is sufficient, then your good
