ground help
Old Aug 31, 2009 | 10:30 PM
patrickstar's Avatar
Default ground help
i had to replace a ground. all i did was strip the wire, and wrap it around the bolt and bolted it back onto the chassis. do i need that ring terminal at the end? or am i fine?
Old Sep 1, 2009 | 04:53 AM
fcm's Avatar
fcm
Old Fart
Default Re: ground help
A proper sized ring terminal should be used. 94
Old Sep 1, 2009 | 07:05 AM
Top Ramen's Avatar
Your solution will work fine for a while but a ring terminal is much more reliable and less susceptible to going bad due to corrosion, etc. over time.
MilanoRedDashR
Audio / Security / Video
15
Jul 3, 2009 05:44 AM
SunkistRex
Mar 15, 2004 01:12 PM
EVILD16BSTD
Sep 24, 2003 04:50 PM
Si-Yaaa!
Jul 14, 2003 12:40 PM
One2chi
Jan 3, 2003 07:12 AM
