Got my valve train!!
Yea i got my valve train about month ago but i just got my head back and here it is!
$$ 1200 for the parts
$$ 750 For JG to put everything in and a 5 angle valve job with Port polishing
Here is the image when it was all finshed!
i went out and bought some ITR's for now, from the dealership, but it dosen't matter, because Ferrera makes a rocker that willl replace the whole rocker assembly, which i belive was priced at 1200 dollars or so for the whole set. (eliminate's the VTEC Effect).
HALF your valvetrain is worth more then my car!!
depends if you are running an N/A motor or a BOOST motor, because your head has to be set up different for each of those applications. (If you are going to make it into a racing motor i pefer you should go with a ferrea set up)
i wnat those...
