got the ELD code what do i do to fix.
Old Mar 28, 2003 | 09:52 AM
KevronsEG's Avatar
Default got the ELD code what do i do to fix.
i just swaped my d16z6 into my crx si. converted to obd1. what does.it mean and how do i fix it? thanks
Old Mar 28, 2003 | 11:59 AM
omahaturbocivic's Avatar
Default Re: got the ELD code what do i do to fix. (CIV616)
It is because your car does not have an eld. It would be located under the fusebox in the engine bay I believe on a car equipped with one. It however does not effect anything and should not cause a check egine light, it just stores a code. Most people do not worry or do anything about it.
Old Apr 22, 2003 | 04:49 PM
crxludeT66's Avatar
im haveing probs with code 20 and it wont go away. it throws the ecu into safe mode and will not rev past 4000 rpm.my car is a 96 obd2 civic with a obd1 b18b non vtech engine . my car from factory does'nt have the eld unit in the fuse box how can i bypass the eld unit so it does'nt flash this code anymore
julianbc2
Feb 11, 2020 12:00 PM
h22integra.eire
Engine Management and Tuning
Sep 14, 2015 06:08 PM
black_99SI
Dec 7, 2007 05:14 AM
nihad
Jul 5, 2007 01:49 PM
