got the ELD code what do i do to fix.
It is because your car does not have an eld. It would be located under the fusebox in the engine bay I believe on a car equipped with one. It however does not effect anything and should not cause a check egine light, it just stores a code. Most people do not worry or do anything about it.
im haveing probs with code 20 and it wont go away. it throws the ecu into safe mode and will not rev past 4000 rpm.my car is a 96 obd2 civic with a obd1 b18b non vtech engine . my car from factory does'nt have the eld unit in the fuse box how can i bypass the eld unit so it does'nt flash this code anymore
