good setup detailed answers
Is this a good setup b16 head with a b20 block
-b16 tranny
-type r valvetrain and cams
-ctr pistons with eagle rods
-frankenstein ecu redlining at 10000
- type r intake manifold
- fuel reg with type r injectors
could i get better cams making power at like 9000+ with a good valvetrain with the ctr pistons and eagle rods but with a stock block and type r injectors
-b16 tranny
CTR pistons doesn't fit into the B20 blocks. The B20 bore is too big for the CTR pistons (81mm pistons V.S. 84mm Bore)
the head setup sounds like a cool street setup.
something like that needs some serious building if you're gunna do that setup i'd say get after market pistons for high compression, and if you can stroke the motor. Or at the very least get some iron sleeves in there, it'll rock the house, if you've got cams that'll make power up high you'd be pushing 250whp n/a easy. The suggestions above are only for reliability sake btw. It'll last a while no matter what, but if you want it to last as long as a stock honda engine (which i doubt) i'd say work on making it the perfect revving monster.
3s1k
May 28, 2010 04:15 PM
pushr0djunk
Feb 15, 2003 05:40 AM
