good gear ratios for high revs?
Old Jul 8, 2005 | 07:34 PM
steronz's Avatar
Default good gear ratios for high revs?
I'm running a b16 with a built head coupled with a stock J1 tranny. The head and cams mean my ideal power band is around 7250 to 9250, and I usually shift around 9500 to make sure i keep the revs high enough and give my stock clutch time to catch up. My best 1/4 is 14.5@95, which doesn't exactly match my power to weight ratio. i finish every race at 95-ish in the top of third gear. it finally dawned on me that me gearing is probably holding me back, but i don't know exactly what to do to fix it. i'm looking at ripping the tranny apart in the next 6 months to add an LSD and LS 5th gear, and i'm thinking there's got to be something i can do to the final drive to help me out. i figure honda changed the ratios pretty drastically between the LS and GSR trannies, and there's only what, 1200 rpms difference between the power bands? surely the ratios designed for a stock b16 redlining at 8200 aren't sufficient for shifting at 9500. does anyone have any ideas?
Old Jul 9, 2005 | 06:35 AM
steronz's Avatar
Default Re: good gear ratios for high revs? (steronz)
bump
Old Jul 9, 2005 | 04:38 PM
steronz's Avatar
one last try, ttt
turbo-crx
Aug 17, 2009 01:39 PM
hondaracing84
Transmission & Drivetrain
Feb 12, 2009 09:44 AM
omgwtfhaxnub
Jul 21, 2008 06:01 PM
steronz
Jul 9, 2005 08:04 PM
