Going from Low imp to High imp, resistor box question
Old Jul 8, 2013 | 09:57 PM
Orangevirus1's Avatar
Default Going from Low imp to High imp, resistor box question
Okay I konw that I have to delete the resistor box.
What wires need to be cut spliced etc?
B18 OBD1 LS
Old Jul 9, 2013 | 07:55 AM
IN VTEC's Avatar
Default Re: Going from Low imp to High imp, resistor box question
For high-impedance injectors, there should be one ylw/blk wire for each injector that supplies switched 12VDC+. All of these will be connected to the resistor box so you'll need to find a way to route 1 wire to each of the injectors.
The injectors will also have a second wire that are pinned individually to 4 separate pins at the ECU. The ECU grounds each one separately to fire. Each GND wire at the injector will be a different color. Don't mess with any of those wires when wiring. Polarity doesn't matter, but it helps to keep the wire colors consistent.
BlownBlackSi
Sep 30, 2006 01:28 PM
vladd
Aug 4, 2006 04:28 PM
ekblacknight
Jun 20, 2005 01:35 PM
Project92Hatch
Feb 16, 2004 03:46 PM
servion
Sep 8, 2003 10:14 AM
