Gear tooth count absolutely BAFFLING!!!
Old Aug 17, 2004 | 02:45 AM
aut0tek's Avatar
Default Someone please close this thread, it got overrun by an idiot.
PLEASE DELETE THIS THREAD... IT WAS RUINED BY A LITTLE KID.
Ratliff
If you had a similar question about weird gear ratio problems... here's the link I ended up with... pretty cool:
http://science.howstuffworks.com/gear-ratio2.htm
Modified by aut0tek at 9:49 AM 8/30/2004
Old Aug 17, 2004 | 11:55 PM
aut0tek's Avatar
Default Re: Gear tooth count absolutely BAFFLING!!! (aut0tek)
bump for someone who knows...
Old Aug 18, 2004 | 05:33 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aut0tek &raquo;</TD></TR><TR><TD CLASS="quote">bump for someone who knows...</TD></TR></TABLE>I don't wanna teach a machine design course here... But it's the diameter, number of teeth, size of the teeth, & all that stuff counts. Even the shape of the teeth matters, whether they mesh together properly.
Say you've got a gearset that's 20 teeth & 40 teeth on the 2 meshing gears. Gear ratio is 2:1 & the 40t gear is twice as big as the 20t. The teeth have to be compatible with each other or they won't mesh.
Now you could design another gearset with the same diameters. But tiny little teeth, 200 teeth & 400 teeth. Same gear ratio, same diameters, same shaft spacing.
Then you can design another gearset with 20 & 40 teeth but different diameters. Now you get the same gear ratio but the shaft spacing is different.
You can't always mix & match because the gear teeth have to mesh together with each other. On a bike it's easy because ALL the gears are made to mesh with the same chain. None of those gears mesh directly with each other.
Old Aug 18, 2004 | 04:17 PM
aut0tek's Avatar
Default Re: Gear tooth count absolutely BAFFLING!!! (JimBlake)
okay, so just the number of teeth is what make up the ratio, nothing else? (in other words, no acceleration is gained by changing the diameter of the gear if it has that same exact number of teeth as the old gear?
Ratliff
Modified by aut0tek at 7:02 AM 8/19/2004
Old Aug 19, 2004 | 03:40 AM
JimBlake's Avatar
Sorta... The gear ratio is determined only by the # of teeth. Beyond that, the diameters determine the shaft spacing. The size & shape of the teeth just determines which gears are able to mesh with each other.
If you change diameter but keep the same # of teeth, that means the teeth HAVE to be bigger. Then they won't mesh with the other gear, so you have to make the other gear bigger to mate with it. That screws up the shaft spacing.
Old Aug 19, 2004 | 04:30 PM
aut0tek's Avatar
I see. But as long as they have the same amount of teeth, the gear ratio will be the same, so no acceleration difference, correct?
Ratliff
Old Aug 20, 2004 | 03:25 AM
JimBlake's Avatar
right
Old Aug 26, 2004 | 04:55 AM
Sliced Beard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">right</TD></TR></TABLE>
WRONG!!!!!
Harry, I explained this to you a long time ago when we were messing with the tranny. Hey, nobody wanted to listen to me......"because I don't know what I am talking about"
lets take your bicycle analogy for example
when you chenge the number of teeth you are actually changing the DIAMETER of one or both of the sprockets. The teeht are only there to keep the chain on a consistant and even path......same principal as the gear. The gear has teeth that have the correct pitch and diameter to mesh properly with each other. The "ratio" is the equation between the two gear diameters....the teeth are only there to mesh and keep in time with each other. Lets use teh analogy that I used the day that I was originally explaining it to you........remember this one........take a shop fan that uses a v-belt pulley system. If you make the larger of the two pullies smaller the fan will spin faster and if you make the smaller pulley larger it will spin slower.....get my point here....teh teeth are only the meshing equation that makes the ratio compatible.
it is really hard to explain gear dynamics.....you have to take measurements and get tooth pitch measurements to fully understand.
I will have to take you to my uncle's machine shop and physically show you what I am talking about the next time I am back in Charleston.
Old Aug 26, 2004 | 04:11 PM
aut0tek's Avatar
Default Re: Gear tooth count absolutely BAFFLING!!! (DirtySol)
whoa there killer jesus. Nobody said you're a ******* idiot, yadda yadda... I just asked for more input. simmer the hell down already.
gawd.
Ratliff
Old Aug 26, 2004 | 08:04 PM
Phelixthecat's Avatar
in this case, the terms are interchangeable - as long as you assume that the teeth are the same size to be able to mesh, simply because, as long as the designers have any common sense, the two measurements will be proportional. as a matter of fact, if anyone here is wrong, it's dirtysol. imagine a gear that is 3ft in diameter and only has 4 teeth on it. when it turns next to a gear with 16teeth, it will turn the 16 tooth gear 1/4 of a turn per its own revolution. now let's take a gear that's 3 inches in diameter, with 4 teeth, spinning next to the same 16 tooth gear. per one revolution of the 4 tooth gear, how many revolutions will the 16tooth gear turn? 1/4th.
Old Aug 28, 2004 | 12:42 PM
Default Re: Gear tooth count absolutely BAFFLING!!! (Phelixthecat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phelixthecat &raquo;</TD></TR><TR><TD CLASS="quote">in this case, the terms are interchangeable - as long as you assume that the teeth are the same size to be able to mesh, simply because, as long as the designers have any common sense, the two measurements will be proportional. as a matter of fact, if anyone here is wrong, it's dirtysol. imagine a gear that is 3ft in diameter and only has 4 teeth on it. when it turns next to a gear with 16teeth, it will turn the 16 tooth gear 1/4 of a turn per its own revolution. now let's take a gear that's 3 inches in diameter, with 4 teeth, spinning next to the same 16 tooth gear. per one revolution of the 4 tooth gear, how many revolutions will the 16tooth gear turn? 1/4th.</TD></TR></TABLE>
all you did was explain that the gear size is proportional. yes if you take a 1/4 scale version of eace gear it will have the same ratio. basically what you said is if you have a 4ft diameter gear and a 1ft diameter gear that it would have the same ratio as a 1ft diameter gear and a 3inch diameter
what I was saying that if the gears have the same tooth pitch as each other but instead of proportionallyt changing teh diameter, instead just change the diameter of the two and you would have a different ratio
4' and a 1' would have a 4:1 ratio
but if you changed the diameter to something like
4' and 6" it would have a 8:1 ratio.....by dividing the variable in half you have just multiplied the ratio by two
now do you get it
Old Aug 28, 2004 | 01:36 PM
Lsos's Avatar
What you're saying is correct, but this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DirtySol &raquo;</TD></TR><TR><TD CLASS="quote">WRONG!!!!!</TD></TR></TABLE>
isn't.
JimBlake is not wrong.
Old Aug 28, 2004 | 01:47 PM
Default Re: Gear tooth count absolutely BAFFLING!!! (Lsos)
tooth count has nothing to do with gear ratio
the diameter of the two gears is what the term GEAR RATIO is all about
Old Aug 28, 2004 | 07:00 PM
Lsos's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DirtySol &raquo;</TD></TR><TR><TD CLASS="quote">tooth count has nothing to do with gear ratio
the diameter of the two gears is what the term GEAR RATIO is all about</TD></TR></TABLE>
If the gears are to actually work, then dividing the tooth counts or diameters will both arrive you at the same number. In fact, the diameters vary slightly due to machining imperfections, so dividing the teeth counts will actually net you the EXACT gear ratio.
Old Aug 28, 2004 | 07:10 PM
ok dude I am not going to argue with you
I have actually manufactured gears at my uncle's machine shop and at one of my previous jobs (Getrag....the sole manufacturer of gears for Diamler Chrysler )
I have had to make/design gears to have a certain ratio within a certain space......and FYI the diameter if the teeth itself is not where you measure, it is where the teeth actually mesh is where you measure
I am not going to try to explain this to the unexperienced because there is a LOT and I mean a LOT more in gear design than I could explain without confusing the **** out of you because I am not very good at conveying points
Old Aug 29, 2004 | 11:51 PM
aut0tek's Avatar
WTF if u worked at such a huge company and they relied on you so much to cut gears, why did u leave?
And how did you get such a great job cutting gears for a huge corporation without going to school?
I barely got a job at RadioShack when I got out of HS.
Ratliff
Old Aug 29, 2004 | 11:54 PM
aut0tek's Avatar
P.S. http://science.howstuffworks.com/gear-ratio2.htm
Old Aug 30, 2004 | 03:10 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aut0tek &raquo;</TD></TR><TR><TD CLASS="quote">WTF if u worked at such a huge company and they relied on you so much to cut gears, why did u leave?
Ratliff</TD></TR></TABLE>
I got a job at Getrag because my Uncle Paul used to be shop foreman at a custom tap and die company that used to do a lot of work for them. They did not rely on me because they had more experienced employees but I have been through the design process and manufacturing process. I quit because Getrag is a horrible company to work for and I am what you call a career student......I love new experiences and I love to learn. every year that I have been out of high school I have spent at least half of it in college (three years now).
BTW: Getrag sucks *****
Old Aug 30, 2004 | 03:51 AM
aut0tek's Avatar
Getrag sucks? Obviously if they are the sole manufacturer of gears for Daimler Chrysler they don't suck.
... and I love this part:
I am what you call a career student......I love new experiences and I love to learn. every year that I have been out of high school I have spent at least half of it in college (three years now). </TD></TR></TABLE>
Gee... Who else spends "at least half" of their first three years after high school in college?
Umm... me? ... And roughly 50% of the United States' High School graduates?
besides, if you've only spent half of your first 3 yrs out of HS in College you're not a "career student" lol.
P.S. Who the hell do you think you are anyways? You use words like: "inexperienced" and phrases like "what you call..." To make yourself feel like you're more important than the next guy.
LOL. Some people on here actually have jobs. Some jobs being WAYYYYYY more important than a "career student" (2A5X3B Auto-Flight, Instruments + Navigation Being a solid contender.)
...Guess I hijacked my own thread. lol. Figured somebody ought to let you know that you're no badass.
Old Aug 30, 2004 | 03:53 AM
aut0tek's Avatar
THANKS TO EVERYONE WHO HELPED DECYPHER THE GEAR RATIO ISSUE...
SORRY IT ENDED UP BEING A "I'M COOLER THAN YOU" CONTEST...
Ratliff
Old Aug 30, 2004 | 04:15 AM
what the hell are you talking about jackass
pull that cucumber out of your *** an wake the F%&# up. I honestly don't care what the hell you think about me and you have no ******* clue what the **** I have been through. You have absolutely no right to judge me and I sure as hell don't think I am better than the next person. I actually have spent the past three years going to college on a regular basis and I already have an associates in business, the only reason why I said "at least half" is because WHEN MY MOTHER DIED I took a few months off from everything. I am sorry I am not up to your "wire probing" standards......I understand that you are in the Air Force and I appreciate the fact that you took the initiative to stand up for the country (and believe me, I tried to join the military but my mother messed that one up for me before she died).......I am glad that I am not an "aircraft electronics specialist" because I don't want to work on airplanes, that is not where my heart is.
I think that I am a education addicted individual and any chance I have to learn something new I take it....that is what I call a career/lifelong student. Yes I have been out of high school since 2001 and yes I am have been in College since I got out, and guess wat I will probably end up doing when I get out of WyoTech......I will probably end up going up to Clemson and finishing up my Mechanichal Engineering degree.
and yes Getrag sucks.....not the quality of the components but how they treat their employees does.
Oh, BTW.....I do have a ******* job and I have done plenty of PROFESSIONAL work......I am a government certified pipe welder....I have done work for the Coast Guard, Navy and I have done many many critical operatons on cargo ships.....heck I have even redesigned a fuel manifold on a 270 foot turbine ship
now go **** off Harry
Old Aug 30, 2004 | 04:54 AM
aut0tek's Avatar
Ladies and Gentlemen... With his brand new hit single: "Cry me a River" Here is... Justin Timberlake...
1. You're not the only one who's lost parents... At least you had the chance to know yours.
2. You obviously DO think you're better... In fact, you told me this on more than one occaision about Chad. "Chad doesn't know what he's talking about I've cut gears before, he hasn't" (Damn near word-for-word)
3. "wire probing" and "aircraft electronics specialist" do not describe my AFSC... And shows your ignorance of the subject.
4. You said more than once in 1 post that your mother is dead. You informed me of this many times before. Just because your mother died doesn't mean you're special. Once again... YOU'RE NOT THE ONLY ONE.
5. Why do you keep talking about you're such an education person blah blah blah... If nobody wanted to learn anything there wouldn't be a forum for it.
6. Nobody gives a **** where your heart is.
7. the Navy eh? Too bad they have their own people to weld... in fact, they're ENLISTED. Which you aren't. thanks for playing.
8. if you "don't care what I think about you" why are you writing an essay in my thread trying to "prove yourself" ?
9. You DO have a job??? Where!?!? lol
10. I'm tired of counting.
So, in a nutshell, read my sig, and go away... The sig applies to you.
Old Aug 30, 2004 | 04:58 AM
aut0tek's Avatar
PLEASE DELETE THIS THREAD... IT GOT OVERRUN BY AN IDIOT.
Old Aug 30, 2004 | 05:20 AM
1. No ****....and Inever knew my father and yes I did know my mother
2. I have never said anything about Chad not knowing what he was talking about....and i have never said anything that about him that he was not there to hear. I did say that I have cut gears and I have and I do not the basic principles of them.....I am not saying that I am an expert but I do have SOME hands on experience with them
3. Like I said before....I do not know what you do and I don't care to
4. I do not think I am "special" for having dead parents.....***
5. I just said the fact that i like to learn and I do so any chance I have
6. eat a dick
7. I HAVE done work for the Navy, thank you......have you ever been out to Deyntn's ship yard or the COAST GUARD docks.....have you ever noticed that there are NAVY ships docked there on a regualr
8. not trying to prove myself....I don't like superficial jackasses that uphold themselves as high and mighty because they are part of the miliotary......there are a few million of you.....like you said YOU ARE NOT THE ONLY ONE
9. I am a part time Acura Tech at Smail Automotive while I attend college
10.once again, eat a dick
Old Aug 30, 2004 | 05:38 AM
aut0tek's Avatar
wow there's more bullshit in there than I ever intended to rectify...
YES... YOU DID SAY CHAD DIDN'T KNOW WHAT HE WAS DOING... DON'T LIE YOU PIECE OF ****.
NOBODY EVER SAID I'M AWESOME CUZ I'M IN THE AF... I JUST SAID THAT YOU THINK YOU'RE AWESOME AND YOU'RE NOT EVEN CLOSE. HAD NOTHING TO DO WITH ME... SO QUIT TRYING TO GET IT TWISTED.
NO **** THERE ARE NAVY SHIPS HERE!?!?!? YOU'RE KIDDING ME!!!. (once again, you show your ignorance) Funny thing is, once again, I talked to some friends at that exact place you speak of... They said that all the Navy stuff is done by their own people. NOT YOU. *sigh*
and look at your number one "I never knew my father" Once again, you're not the only one, and that doesn't make you special.
NOW READ THE GODDAMNED SIG AND GO THE HELL AWAY
