Gauges????
Old Jan 27, 2003 | 04:50 PM
XxDemonxX's Avatar
Default Gauges????
i did a search and didnt find to much (anything) to help me out. How do i run these wires to the appropriate area isnt really my concern....YET. But how do i take a part the car and RUN the wires. I'm installing the fuel pressure gauge. I am pretty sure it runs to that white wire that comes out from ur header. But not sure anyone help me out here? How do I get it to the interior of my car? I have a 2 gauge pod going on the A pillar.
[Modified by XxDemonxX, 1:51 AM 1/28/2003]
[Modified by XxDemonxX, 2:10 AM 1/28/2003]
Old Jan 27, 2003 | 05:03 PM
IN VTEC's Avatar
Default Re: Gauges???? (XxDemonxX)
installing the fuel regulator gauge. I am pretty sure it runs to that white wire that comes out from ur header.
This one's a real stumper. What kind of gauge(s) do you have? Try to use colloquial terms, like: Fuel pressure gauge, oil pressure gauge, exhaust gas temperature (EGT) gauge, air:fuel ratio (AFR) gauge.
I'm guessing it's an air:fuel ratio meter that you want to install.
A panel = A-pillar
holder = pod
As for getting the wires into the interior, you'll need to find a grommet (rubber cap) that'll allow you to feed the wires all the way in.
Old Jan 27, 2003 | 05:10 PM
XxDemonxX's Avatar
Default Re: Gauges???? (IN VTEC)
the fuel pressure gauge......
Old Jan 27, 2003 | 05:17 PM
IN VTEC's Avatar
What brand of fuel pressure gauge?
Old Jan 27, 2003 | 05:42 PM
tominos's Avatar
white wire on your header? that would be your o2 sensor my man. is it electrical or mechanical? and you can route the wires from your engine bay to the inside of your car through the firewall.
Old Jan 27, 2003 | 05:54 PM
XxDemonxX's Avatar
Default Re: Gauges???? (tominos)
thanks ya'll........ my texas accent at its best
TurbothisLS
Mar 18, 2004 05:31 PM
Boosted_MRCSI
Aug 3, 2003 04:41 PM
jasonb
Mar 28, 2003 06:00 PM
Sprockets
Mar 25, 2003 06:12 PM
