Gaskets and Seals
Old Dec 24, 2005 | 04:49 PM
Rukusmasta2's Avatar
Default Gaskets and Seals
cant someone please identify to me these
Old Dec 24, 2005 | 05:37 PM
Lord Helmet's Avatar
Default Re: Gaskets and Seals (Rukusmasta2)
all the 0-rings are gaskets and the flat piece lying below it is a gasket too. the piece in the plastic bag is a seal. but then again the seal looks like a wheel bearing though.
BTW what do you have it for if you don't know what's what?
Old Dec 25, 2005 | 05:54 AM
Default Re: Gaskets and Seals (Lord Helmet)
all u basically said is what im askin????? i got it because from acura its called a bottom end gasket kit...i know that there seals and gaskets im askin w here they go
Old Dec 25, 2005 | 11:35 AM
projectTeG's Avatar
looks like the main seal, o-rings for the oil pump, o-rings for some othere things and the gaket that goes on the bottom outter timing cover/
Old Dec 25, 2005 | 01:10 PM
Default Re: (projectTeG)
i already installed the rear main seal, the o rings dont fit on the oil pump, so i got 3 rings where i have no idea they go and i think that is the gasket for the bottom outter timing cover....still lost....BUMP
Old Dec 25, 2005 | 01:23 PM
projectTeG's Avatar
well i know one of those o-rings go to the oil pick-up.
Old Dec 25, 2005 | 11:06 PM
jdm91integ's Avatar
The 2 o-rings in the top left corner, lool like they go on the ends of the water pipe on the back of the block. The water pipe that the thermostat housing is connected to.
Old Dec 26, 2005 | 11:25 AM
Default Re: (jdm91integ)
BUMP
raverx3m
Jan 13, 2011 01:30 AM
ex voto
11
Oct 2, 2005 01:16 PM
O16581724 5 2 5
Jun 23, 2005 07:07 PM
TallKyle
Feb 17, 2005 11:41 AM
Jonathan_ED3
Apr 11, 2003 09:02 PM
