Fuel system question
Old Dec 25, 2010 | 02:06 PM
Ramon96LS's Avatar
Icon6 Fuel system question
I am having a problem with my fuel pump not turning on for those three seconds when I turn the ignition on. Now I checked the relay and it does work (put it in a friends car) So im stumped...Now everything was working 8 months ago when I parked the car due to spun bearing. So I dont believe it would be the pump.
Any ideas...would the ecu have something to do with this? A friend of mine was using my ecu said he had no problems. Oh and I just swapped another ls motor into it.
Car is a 96 Acura Integra ls OBDII
Old Dec 25, 2010 | 02:42 PM
tonythetuner®'s Avatar
Default Re: Fuel system question
Did you connect all your grounds and the one on the >theromstat<
Old Dec 25, 2010 | 03:26 PM
Ramon96LS's Avatar
Haha Thanks man It was not tighten all the way It starts now...but now on start up it does not idle it shoots to red line aahhhh! Any other suggestion?
Old Dec 27, 2010 | 07:19 AM
lsturbo33's Avatar
Get your foot off the gas! jk Possibly a large vacuum leak or the throttle cable may not be adjusted properly.
bigbangmtl
May 10, 2011 07:39 AM
BlueStar
Dec 12, 2008 12:32 PM
aznoophi
Mar 30, 2008 01:06 PM
sacjdmz
Aug 27, 2005 12:58 PM
Civichatch27
Jun 19, 2004 09:22 PM
