Fuel rail and injectors?
Old Feb 14, 2006 | 08:24 AM
lowridincivic92's Avatar
Default Fuel rail and injectors?
ok i jsut swapped a d16a into my 92 vx. and i have a y8 IM to put on but i am trying to figure out if the fuel rail and injectors from the 1.5 IM will fit and what issues would i have? Thanks
Old Feb 14, 2006 | 05:52 PM
eda6's Avatar
Default Re: Fuel rail and injectors? (lowridincivic92)
I don't have a definate answer but you could go to http://www.hondaautomotiveparts.com to see if they're similar and check parts numbers.
or you could just try it and see what happens.
Old Feb 14, 2006 | 07:14 PM
Slow_import's Avatar
injectors will fit but you will need the y8 manifold fuel rail....some of the sensors wont hook up but it will be fine....the y8 fuel rail only has two mounting bolts, your stock one needs 3....
Old Feb 14, 2006 | 10:08 PM
ok thanks. i am getting the fuel rail and injectors pretty soon.
leroyb
Jun 19, 2009 12:13 PM
puertoricanboy90
Jan 2, 2009 04:25 PM
Ryan124
Jan 12, 2006 09:58 AM
Matt B
Sep 22, 2004 02:44 PM
