Fuel pump prime Q"
Old May 2, 2005 | 04:11 PM
vtekthis's Avatar
Default Fuel pump prime Q"
i have my motor out as of right now, and i want to check my fuels system for leaks. My problem is, if everything disconnected the fuel pump will not prime? mine wont, with my stock comp or aftermarket. Is this supposed to be? i think it might but not sure
thanks
Old May 3, 2005 | 02:05 AM
vtekthis's Avatar
Default Re: Fuel pump prime Q" (vtekthis)
upp
Old May 3, 2005 | 04:45 AM
JimBlake's Avatar
It probably depends on what's removed or disconnected in your case. If the ECU, main relay, & most wiring are still in place, it should work.
Old May 3, 2005 | 08:08 AM
vtekthis's Avatar
Default Re: Fuel pump prime Q" (JimBlake)
all the wiring is still in place, i reinstalled the ecu and no prime, just the whole engine is disconnected
Old May 3, 2005 | 08:32 AM
JimBlake's Avatar
I guess I don't know what's different. I'd wanna see a wiring drawing for YOUR model & year before I pretend to know too much. I really didn't think the engine physically has to be there.
Got a Helm book? Maybe some of the ECU/mainrelay/fuelpump circuits travel thru a wiring harness that you've got disconnected? Have you unplugged some of those connections near the brake master cylinder?
Does your engine have a group of ground wires at the thermostat? Maybe that's what's missing? Your ECU won't power up without (+) AND (-) power.
Old May 3, 2005 | 08:46 AM
SOHCmaster's Avatar
not sure, but you can always do a direct wire to pump set up
Old May 3, 2005 | 09:05 AM
vtekthis's Avatar
Default Re: (PK SPEED)
i was gonna try that but thought it would power up without the engine.
Jimblake- yes it does have a group of groung staps on the thermostat, thats what i figured too would be the reason the ecu wouldent power up. Its a 99 ex chassis and harness if it helps
Can anyone positively agree with this
Old May 3, 2005 | 10:22 AM
JimBlake's Avatar
Default Re: (vtekthis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtekthis &raquo;</TD></TR><TR><TD CLASS="quote">... Its a 99 ex chassis and harness if it helps...</TD></TR></TABLE>So what is it? Your signature says '91 Civic SI. It's a '99 Civic EX?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtekthis &raquo;</TD></TR><TR><TD CLASS="quote">... yes it does have a group of groung staps on the thermostat, thats what i figured too would be the reason the ecu wouldent power up...</TD></TR></TABLE>So did you try taking that bundle of wires & grounding them?
Old May 3, 2005 | 05:31 PM
vtekthis's Avatar
Default Re: (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">So what is it? Your signature says '91 Civic SI. It's a '99 Civic EX?
My sig says "another black t4 coupe from the east" and a 91 daily
No i did not ground them yet im gonna try tomarrow
Old May 5, 2005 | 07:58 AM
vtekthis's Avatar
update- the coolent ground has to be grounded for the ecu to read power, fuel pump primes!
renzis00
Mar 10, 2013 05:26 AM
reddcoupe
May 17, 2012 02:52 AM
Naudlee
12
Nov 25, 2008 11:27 AM
Laurence
Sep 5, 2004 05:22 PM
