Fuel pump issue
Old Jul 15, 2010 | 11:35 AM
Psychoteen101's Avatar
Default Fuel pump issue
93 civic hatchback with a 255 pump. It will not prime and will not run. I have power going to and coming out of the main relay. The relay tests good. I have 11.8 volts going to the pump with the key ON. I replaced the pump with a new 255 and still it does not prime nor run. Any suggestions on where to look next?
Old Jul 15, 2010 | 12:08 PM
Former User's Avatar
Default Re: Fuel pump issue
Test the fuel pump ground wire for continuity to body ground. It may be bad.
Old Jul 15, 2010 | 02:53 PM
your talking about the ground thats actually on the fuel pump housing assembly in the tank correct?
Old Jul 15, 2010 | 04:02 PM
Correct. The black wire.
Old Jul 15, 2010 | 04:44 PM
got it figured out. Test light was very dim at that wire. Traced it down the line and noticed the ground was not hooked up at the chassis brace parallel to the drivers door. Must have forgotten to hook it up when i put my harness in. All good now. Thanks!!
Thor777
Nov 27, 2011 07:07 PM
pleej
Apr 8, 2011 11:06 AM
RICE POLICE SIP
Apr 21, 2010 03:26 PM
crxfreak1117
Aug 15, 2009 06:09 AM
Preludes'R'Us
Mar 11, 2008 11:01 PM
