fuel pump / filter
Old Mar 27, 2003 | 08:05 PM
ThrillaKilla's Avatar
Default fuel pump / filter
would a bad fuel filter or fuel pump contribute to preventing my car from starting from time to time.... when i start it it idles extremely low barely kicking over and in most cases wont rise RPMs and die... when i try and kick it over again it just winds over and over on the batterys power... after about 10 minutes it will fire up in a heartbeat and be ready to roll..... my hypotheses is that it could be either the fuel pump, fuel filter, or bad injectors...? ] any thoughts appreciated... tia...
oh yeah i forgot... when i bought the car it came with a generic brand """MUGEN""" chipped PR3 with "increased fuel mapping and 4k vtec x-over" ............. anyway i was thinking that the fuel mapping is causing my car to run rough in the low RPM stages... and we all know 4k is a bit low to be fondling with vtec.... do you guys think this generic brand BS chip could be contributing to and/or causing this rough start problem??
do i have to buy a new ecu to get rid of this chips 'features' (im assuming its soldered) or can i just reset the ECU or something??
[Modified by ThrillaKilla, 5:11 AM 3/28/2003]
Old Mar 27, 2003 | 08:54 PM
Default Re: fuel pump / filter (ThrillaKilla)
Old Apr 1, 2003 | 10:10 PM
Old Apr 1, 2003 | 11:05 PM
evo's Avatar
evo
New User
I have the same problem as you have, after I installed used 390CC DSM injectors, I guess you should look at fuel pump/injectors.
Old Apr 1, 2003 | 11:11 PM
Quik Chris's Avatar
Default Re: fuel pump / filter (evo)
No, this is a way common misconception.
I'd check the distributor cap and rotor first. If you're still running stock wires after 50k miles since the last change, I'd opt to change those. Also, if you haven't changed your plugs in that time, now would be a good time to change them.
Next I'd check all my vacuum lines to make sure they weren't leaking. Could also be an intake manifold or throttle body gasket.
Also: Let me help you in another way. This isn't superhonda, and we don't list our mods in our signature, you're going to get flamed.
[Modified by Quik Chris, 1:13 AM 4/2/2003]
Old Apr 1, 2003 | 11:17 PM
Quik Chris's Avatar
Default Re: fuel pump / filter (Quik Chris)
You may want to change that ECU back to stock. You can find LS ECU's w/o too much trouble. Sounds like it's dumping too much fuel in for a near-stock car.
hermtm2
23
Apr 8, 2009 06:17 PM
islnder102
Sep 26, 2006 01:08 PM
crnimacak
Apr 21, 2006 10:11 PM
Xenobi
Jan 26, 2006 09:24 PM
The_In_Kid
May 15, 2002 12:33 PM
