Fuel Pressure Tips
Old Apr 26, 2003 | 10:17 PM
_BURN_'s Avatar
Default Fuel Pressure Tips
what psi should i be running? 95 ls motor with big fuel pump, bolt-ons and mild turbo cams.
Old Apr 27, 2003 | 06:47 AM
pills_PMD's Avatar
what engine management are you using??
do you have a turbo? or just the cams...?
Old Apr 27, 2003 | 04:33 PM
_BURN_'s Avatar
no stand alone / hondata yet. 91 ls pre-odb ecu. the car is going to be turbo'd in a month or two. the car just has the turbo cams right now. im going to the track in a few days and i just want the engine to put out all it can for a last 1/4 mile time so i can compare it to when im turbo.
Old Apr 28, 2003 | 04:36 PM
_BURN_'s Avatar
bump cuz i needa answer
Old Apr 28, 2003 | 05:06 PM
Neukin's Avatar
Default Re: (_BURN_)
just put on 50psi it wont hurt anything just help thats good enough
Old Apr 28, 2003 | 11:23 PM
MPower332TI's Avatar
Default Re: (toyosupr)
50 psi will be to much. It will miss and bog. I would want to see about 40-45 on WOT. No more than 45 without the turbo.
Old Apr 29, 2003 | 04:30 PM
Neukin's Avatar
Default Re: (jDmDxTuRd)
stock is like 35-40psi
Old May 5, 2003 | 05:40 PM
B18BGuy's Avatar
This relates to a ? I have also, with a stock ls motor w\bolt-ons. After 4K RPM WOT and regular cruising (2.5K RPM) I seem to be running pretty lean (13-15 A\F ratio.) I'm currenly at 38 PSI fuel pressure. How high can i take it without over working my injectors?
Old May 14, 2003 | 01:33 PM
_BURN_'s Avatar
thanks guys. its now set to 43. its was running rich at 45
Old Jun 25, 2003 | 01:11 PM
civicB18B1's Avatar
I have 34 psi at 2000rpm with my B18B 1999 with I/H/E, 65mm TB and intake ported.
What's the best pressure at 2000rpm with my set up???
Old Jun 25, 2003 | 02:19 PM
raene's Avatar
Default Re: (civicB18B1)
I have my B16A set to 38psi (stock setting)... richening it up, leaning it out, nothing seems to make that much of a difference and I've played with it for quite a bit since I have nothing else to tune on the engine
Something to think about.
Gamefreak0109
21
Jun 8, 2007 02:00 PM
92civy
Oct 13, 2006 09:12 PM
fieromadman
Apr 29, 2006 06:37 PM
MarkAngelo
Sep 23, 2004 05:51 AM
djnikko
Dec 7, 2003 10:42 AM
