fuel pressure question??
Old Feb 4, 2009 | 10:47 AM
stevecod's Avatar
Default fuel pressure question??
i installed a fuel pressure guage on to the fuel filter and notice that the guage is reading 34psi at idle ( which is normal) but the funny thing is when i turn off the car the guage drops down to 28psi?? shouldn't the pressure be at 0 with the car off?
Old Feb 4, 2009 | 11:01 AM
scmil95eg's Avatar
Default Re: fuel pressure question??
No. Most OEM pumps have a check valve on the outlet so you keep fuel in the rail after the pump is turned off. It helps a little when you re-start it. Install a Weldon, then you'll have 0 psi when you turn it off. lol
Old Feb 5, 2009 | 10:06 AM
acurtech6090's Avatar
after you shut off the car there should be "holding press." thats how u tell if u have a leaky injector
turbo-crx
May 23, 2009 01:30 PM
cashshoes
Oct 19, 2006 12:09 PM
jman86
Aug 26, 2006 08:13 AM
Shmaa
Jul 7, 2006 04:59 PM
hybridpatient95
15
Feb 10, 2006 07:03 AM
