Fuel line problem
Old Feb 8, 2004 | 06:07 PM
Alpha_GSR's Avatar
Default Fuel line problem
I hate to say it, but I driledl through a fuel line running one of my amps under my drivers seat. Now there is gasoline trickling down. Guys, can you give me some information on how much it is to fix the lines, and if it is hard? Is it possible to fix it yourself? My car is a 94' GSR.
Thanks in advance.
Old Feb 8, 2004 | 11:35 PM
mmuller's Avatar
Mad Scientist
Default Re: Fuel line problem (Alpha_GSR)
you could take the line out and get it welded, or buy new one
Old Feb 8, 2004 | 11:50 PM
500hpsi's Avatar
Default Re: Fuel line problem (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">you could take the line out and get it welded</TD></TR></TABLE>
bad advise
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote"> buy new one</TD></TR></TABLE>
good advise so I agree buy a new one
Old Feb 9, 2004 | 05:33 AM
integra6650's Avatar
Default Re: Fuel line problem (NAPA182)
or if your seriously depressed you can weld it on the car jk dont do thatwhat kinda work you have in the car is it worth running performaflex or just run a new line. it will be like 20 bucks if you need a bender and cuter and the pipe but its very easy
Old Feb 9, 2004 | 07:38 AM
mmuller's Avatar
Mad Scientist
Default Re: Fuel line problem (500hpsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 500hpsi &raquo;</TD></TR><TR><TD CLASS="quote">
bad advise
good advise so I agree buy a new one</TD></TR></TABLE>
mmmmmm, why is it a bad advice??please elaborate
Old Feb 9, 2004 | 10:57 AM
B18C2_sedan's Avatar
mmmmmm, why is it a bad advice??please elaborate</TD></TR></TABLE>
What is a fuel line psi 40 or so. Proof test the welded to 100 psi and your good to go.
Old Feb 9, 2004 | 11:17 AM
mattssi's Avatar
I wouldn't weld it, but that is just me. I would replace it! Or put in a new section where you drilled it at least!
"stereo systems are the devil bobby"
Old Feb 9, 2004 | 01:20 PM
Alpha_GSR's Avatar
thanks guys, i'm getting it fixed as I speak... I just forgot the golden rule of installing stereo equipment, "always check before you drill!"
I'm glad this nightmare is working out...
Old Feb 9, 2004 | 01:47 PM
snoochtodanooch's Avatar
Default Re: (Alpha_GSR)
welding it seems awful stupid, i just don't see how you could be sure of your inner diameter, and isn't worth the effort of ******* it up. Cut a section out of the bad. get some new fuel line, put the fittings on both the new section and the old line, flare the ends with the tool, and bolt them up. Shouldn't cost more than 20 bucks if you can borrow the tools from someone.
Old Feb 9, 2004 | 02:36 PM
mmuller's Avatar
Mad Scientist
Default Re: (snoochtodanooch)
To whoever is saying welding it is stupid, please explin why....
cut the line and weld a piece. simple and not stupid.......
mixmastermatt
Feb 5, 2007 11:07 AM
kadidle
Jan 30, 2007 07:05 PM
gitrdone
Honda Civic (2001 - 2005)
Jan 3, 2007 10:47 AM
huge230
Jan 2, 2006 11:23 AM
SpeedDreamz.com
May 30, 2004 02:07 PM
