fuel injectors not injecting
My H22A/Accord has a little problem...........
My fuel injectors arn't working. I already check each of my ECU's(stock & prelude) so it's not a computer problem.
some one told me that it might be a problem with one of the pins on one of the sides of the harness
any Ideas are welcomed
What injectors are you using. Did you change the wire harness or not. I would check the continuity of the wires between the ecu plug and the injectors also injector to resistor block. Corrosion is easy to spot on th eplugs just look at them and make sure they're ok.
bootlegcivic
Aug 6, 2005 10:07 PM
