Fuel Pr hose?
Old May 26, 2003 | 11:01 AM
Rising sun #1's Avatar
Default Fuel Pr hose?
I read somewere that if you remove the hose that leads from your fuel pressur regulator to your intack plenum that it will boost pressur, is this true and or any benifits.
Old May 26, 2003 | 12:13 PM
Archidictus's Avatar
Unceasing Measure
Default Re: Fuel Pr hose? (Rising sun #1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rising sun #1 &raquo;</TD></TR><TR><TD CLASS="quote">I read somewere that if you remove the hose that leads from your fuel pressur regulator to your intack plenum that it will boost pressur, is this true and or any benifits. </TD></TR></TABLE>
That hose is there for a reason, don't **** with it. Even if there were some benefit from increasing vacuum at the manifold, it wouldn't be noticible.
Old May 26, 2003 | 01:39 PM
mr.beeks's Avatar
Default Re: Fuel Pr hose? (Archidictus)
there are no benefits
by doing this
dont forget that hose controls your fuel presure at a certain
rpm's so it fluctuates your pressure.
if you remove it, you will run at a steady pressure
so thats not good..
crxpwr1
Dec 10, 2006 08:14 PM
deadly_sleeper
Dec 16, 2005 09:01 PM
robdog09
Jul 3, 2005 02:11 PM
EGhatch22
Dec 31, 2004 11:33 AM
comptechgsr2000
Feb 13, 2003 04:17 PM
