FS: A Bunch of Parts
99-00 B16A2 Parts
Windage tray $10.00
Oil Pan $50.00
Water Pipes $10.00
IM support brackets $15.00
Alternator & Brackets $110.00
TB cover top inside $10.00
TB cover top outside $15.00
Oil Pickup $10.00
Cranks $75.00
Intake Valves $50.00
Timnig Belt used 15k $10.00
99+ B-Series Parts
Breather Chamber $10.00
Fuel line $10.00
Block to Trans Bracket small $10.00
Cam Rails $25.00
Knock Sensor $50.00
IACV $50.00
Map Sensor $30.00
Cylinder Head Coolant Sensor $10.00
EVAP Sensor/Valve $50.00
99-00 GSR Parts
IM support bracket $15.00
Exhaust Manifold $20.00
Starter $60.00
TB Cover Lower $25.00
TB Cover upper outside $20.00
TB Cover upper inside $15.00
99-00 Si Parts
Rad Tank $20.00
Rear Motor Mount $30.00
Rear Tranny Mount $25.00
Hollowed cat $10.00
Swaybar w/o endlinks $15.00
Springs $40.00
Pass. Axle $40.00
AEM CAI $70.00
Shift Linkage $80.00
Driver Air Bag $90.00
Underdash Fuse Panel $20.00
DoorPanel Covers/Switches $50.00
EG Parts
Hatch $50.00
Wing $30.00
Doors $100.00
Driver Fender $40.00
Head lights $40.00
Tail Lights $30.00
00 ITR Parts
Fuel Injectors $70.00
Oil Squiters $40.00
Misc. parts
Shock Tops $10.00
Misc. Plugs
96+ SOHC Parts
Rear Mount $10.00
AC Mount $10.00
96 D16Y5 Longblock $150.00
Please PM or email me at ruizdpdx@aol.com
Leaving next month for the Air Force so i need to get rid of these things
Windage tray $10.00
Oil Pan $50.00
Water Pipes $10.00
Oil Pickup $10.00
Cranks $75.00
99+ B-Series Parts
Fuel line $10.00
Cam Rails $25.00
Knock Sensor $50.00
IACV $50.00
Map Sensor $30.00
99-00 GSR Parts
Starter $60.00
99-00 Si Parts
Rad Tank $20.00
Hollowed cat $10.00
Springs $40.00
Pass. Axle $40.00
AEM CAI $70.00
EG Parts
Hatch $50.00
Wing $30.00
Doors $100.00
Head lights $40.00
Tail Lights $30.00
00 ITR Parts
Oil Squiters $40.00
Misc. parts
Shock Tops $10.00
Misc. Plugs
96+ SOHC Parts
Rear Mount $10.00
AC Mount $10.00
