Frying ECU's
Old Oct 7, 2005 | 06:26 PM
1FastCoupe's Avatar
Default Frying ECU's
A buudy of mine has a 97 LS Integra and every so often it will totally fry the ECU..We change the ECU and the car starts up and runs fine. when the ECU dies it wont Idle and turn off. We have gone through about 4 ECU's and even did the OBD1 conversion and the same thing happens. What could be a possible cause of this?.. Im going nuts here.We know its not as simple as resetting the computer because we tried one of the dead computers in someone elses car and it doesn't work...
Old Oct 7, 2005 | 09:37 PM
Steve-o's Avatar
Default Re: Frying ECU's (1FastCoupe)
you might have a ground or a direct short to ground problem?! check all ground wires, you could have hot wires crossing other wires, it is weird that the fuse does not blow!
Old Oct 9, 2005 | 07:18 PM
1FastCoupe's Avatar
I thought that was weird too that it doesnt blow the fuse. I dont know whether to try replacing the dash harness or the engine harness.
91siguy
Jun 10, 2008 09:56 AM
j-specB20sol
10
Oct 23, 2007 04:37 PM
1000_miles
Nov 4, 2006 11:02 PM
AzntaggeR
Feb 19, 2006 06:54 PM
qwklude82
Aug 21, 2002 11:47 PM
