frozen locks with white lithium grease
Old Jan 12, 2013 | 11:57 AM
raverx3m's Avatar
Default frozen locks with white lithium grease
Last 2 days been realy cold and in the morning my lovk mechanism is frozen i cant turn the key
The key cylinder works and turns to lovk but not unlock.
Everywhere i see people recommend white lithium grease.
I go through pass foor and cant even open the driver from the inside
Everything is greased up and cleaned when i took them out during painting
Is there better type of lubricant for door locks?
Old Jan 12, 2013 | 05:56 PM
raverx3m's Avatar
Default Re: frozen locks with white lithium grease
bump gotta go through same thing tomorrow morning any advice?
so far i only saw same advice everywhere to use lithium grease but it is there and frozen
Old Jan 12, 2013 | 06:56 PM
stumpyf4's Avatar
Ice forming in the lock cylinder over night? Use Wd40 to displace the water then what ever lubricant u wish. I'd only use the wd40, the other stuff would get messy.
Old Jan 12, 2013 | 10:06 PM
raverx3m's Avatar
wd40 washes out all the lubricant.
it has cleaning agents or solvents whateve its called.
i used wd40 once and it dried out all my locks in about 5-6 months they seized dry
now that i think about it. i didnt clean them on this car i did it on last del sol i had before it.
i think its the old grease freezing..
thanks for reply tho
Old Jan 13, 2013 | 03:10 AM
holmesnmanny's Avatar
just hit it with some PB...it might smell a little but the smell will subside after a day or so
Old Jan 14, 2013 | 05:11 AM
kyden's Avatar
i spray it with w40 once every winter. never had an issue since.
Old Jan 21, 2013 | 09:43 AM
electron blueSi's Avatar
I used "Lock Deicer" which can fit in the key hole. Is the key warn out?
panchlow
Oct 27, 2011 05:45 PM
Re3irth
Dec 7, 2007 03:24 AM
graveltravel2
11
Feb 21, 2007 03:43 AM
soloIntegra
May 12, 2003 12:32 PM
TeamTooQuick
Mar 11, 2002 06:54 AM
