Front brake conversion
Old Jul 22, 2004 | 08:44 PM
docmanakos's Avatar
Default Front brake conversion
I have a 1995 Del Sol and I went to the Honda dealership service center and asked if I could just change the size of my front rotors from the stock 9.44 ones I have on now to the larger 10.3. He said if they fit on then no problem. But if I was to change the rotors without having larger calipers with larger brake pad area, what good would it do, since the braking surface area would be the same?
Any comments?
Docmanakos@aol.com
Also the rear lower control arm bolt broke any suggestion for that, I wanted to put in my new koni yellows.
Old Jul 24, 2004 | 02:03 PM
docmanakos's Avatar
Default Re: Front brake conversion (docmanakos)
No comments from anyone?
Old Jul 24, 2004 | 09:05 PM
wzcb08's Avatar
Depending on how well the rotor was built. I would just say that it increases your area to dissapate heat. Not too mnay benefits from a rotor alone.
Old Jul 24, 2004 | 10:19 PM
murtnabila's Avatar
Default Re: Front brake conversion (wzcb08)
I don't see how it would help either, same brake pad covering same area and the distance of the caliper would be same so even that don't help.
Old Jul 25, 2004 | 08:05 AM
docmanakos's Avatar
Default Re: Front brake conversion (murtnabila)
I agree absolutely, I'm not exactly sure what this guy was talking about. Do anyone know the name of the Salvage yard book of interchangeable parts?
usdmftw
Mar 26, 2012 04:02 PM
NegativeLift
12
Mar 23, 2011 04:40 AM
docmanakos
Jul 25, 2004 09:29 PM
makaveli284
12
Mar 26, 2003 07:10 PM
bluedelsol
Feb 19, 2003 09:22 PM
