Front alignment question!
Hey guys, I was wondering if when they do an alignment (this is on a 93 DA) they have to remove the castle nut on the outer control arm? I aks because Im changing the inner and when taking off the outer I screwed up the threads badly, and I know this time when the nut goes back on it will be the last time. Someone please let me know. Thanks!
I also assume just that the lock nut is loosened and the inner tie rod spins in/out of the sleeve inside the outer tie rod? Meaning the outer isnt removed at all? Please help!
CleanHatch
Oct 23, 2005 02:13 PM
