Fried ECU, thoughts??
Old Jun 12, 2024 | 12:04 AM
Eth2077's Avatar
Default Kckkc
i
Old Jun 12, 2024 | 04:52 AM
theYBLEGAL's Avatar
Loved
Default Re: Fried ECU, thoughts??
https://www.homemadeturbo.com/engine...da-ecus-98549/
The board took some damage for sure. It can be saved by remaking the traces with small pieces of wire and some creative mounting of parts. Is it worth it? Eh. Glad you got another one coming. Better stand alone ecu's are becoming very affordable as well.
Old Jun 12, 2024 | 06:12 AM
Ryanthegreat1's Avatar
Isn't that the area that gets scorched when someone swaps the plugs for map and iat? Or was it map and iacv. They are the same plug but one is 5v and the other is 12v.
Old Jun 12, 2024 | 06:24 AM
theYBLEGAL's Avatar
Loved
On some ecu's Q31 is near there and that would be the transistor that pops when the plugs are switched.
In this case this 11F0 board has a capacitor that blew its guts out. The acid is what ate out the board. Thats supposed to be C14 with a 220uf 35v capacitor.
I had an ecu sitting nearby...
Old Jun 12, 2024 | 09:03 AM
Well that helps rule out popping the replacement as soon as it's plugged in.
Old Jun 12, 2024 | 09:09 AM
theYBLEGAL's Avatar
Loved
Yeah change those caps out right away if no one else has. (The new one)
Old Jun 12, 2024 | 10:46 AM
Eth2077's Avatar
X
Old Jun 13, 2024 | 07:47 AM
theYBLEGAL's Avatar
Loved
The capacitors rupture from age. Nothing in the car should have aided in that failure, typically.
NewHondaMan1984
Honda Civic (2006 - 2015)
Oct 17, 2021 06:16 AM
Moog_enep3
Feb 11, 2016 03:19 PM
nick91civicsi
Engine Management and Tuning
Oct 25, 2009 03:27 PM
MaWeiTao
Apr 11, 2005 11:39 AM
c for sea
Apr 17, 2004 07:13 AM
