Forced Piston Ring question
Old Mar 17, 2008 | 09:37 AM
EF8 D-UNIT's Avatar
Default Forged Piston Ring question
I bought a block used, with Endyn Roller wave pistons in it with eagle rods ect.
It's been used for about 2 years on a low boost supercharged setup. NO SIGNS OF FAILURE
I know I SHOULD replace the rings, but I'm not too sure what rings to buy - do I buy Chromoly's with the pistons size, or
Do I order Endyn rings.
Also I'm not positive on the actual piston being used, it could only be one of two - and being FI I would think it's the lower CR piston
Any ideas? I wanna just throw the head on an go, but my setup is not as tiny and will see mid 20's in psi on a SC50E
Any hep would b great.
Old Mar 17, 2008 | 02:45 PM
King V's Avatar
Default Re: Forged Piston Ring question (EF8 D-UNIT)
Chromoly rings have a tendency to burn/consume oil (more than a "regular" ring set), as they are a harder alloy. I would get Endyn rings, as they should be a match of sorts for those pistons.
blub16hatch
Nov 29, 2006 09:40 AM
crex23
Feb 2, 2006 05:41 PM
Slick GS-R
May 13, 2002 07:40 AM
Slick GS-R
May 13, 2002 07:15 AM
