flywheel question for gsr motor
Old Mar 22, 2008 | 11:23 AM
djhonda247's Avatar
Default flywheel question for gsr motor
I bought an ACT streetlite flywheel for my 94 gsr motor and installed it, but the instructions never said anything about TDC. There was a machined marking on the flywheel that I will assume is a TDC marking. One of my buddies says that the flywheel needs to be installed TDC and I am finding conflicting stories on the net. What is the correct way? Does it matter?
Old Mar 22, 2008 | 01:47 PM
inspyral's Avatar
The "machined mark" is probably a result of the balancing process. TDC shouldn't matter with a flywheel because it is balanced.
Old Mar 23, 2008 | 09:02 PM
Brick Top's Avatar
Default Re: (inspyral)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral &raquo;</TD></TR><TR><TD CLASS="quote">The "machined mark" is probably a result of the balancing process. TDC shouldn't matter with a flywheel because it is balanced.</TD></TR></TABLE>
it doesn't matter.
hypa
May 2, 2013 09:56 AM
Boostage
Jul 5, 2007 03:01 PM
mrx
Oct 1, 2004 11:17 AM
scrap1ngsr
Jun 19, 2003 01:57 PM
