flooded b16a no start?
Old Jul 19, 2015 | 05:50 AM
civiclx23's Avatar
Default flooded b16a no start?
I have a 91 sir replica with a B16a swap. Zdyne tuned computer and Apexi vtec controller. Aftermarket fuel rail and 70mm throttle body. Drove it to town and it started bogging out and wouldnt move but smelt like gas. What could bet he issue with the injectors?
Old Jul 19, 2015 | 05:54 AM
ferio-ichi3's Avatar
Ferio Wdm Edition
Default Re: flooded b16a no start?
Probably dumping a shitload of gas. What size injectors?id look to get another ecu to see if thats the issue.. Most likely it is.
Old Jul 19, 2015 | 06:27 AM
Runnerdown's Avatar
You probably have a distributor component failure and there is no spark. Report back after the basics have been checked...
Old Jul 31, 2015 | 12:39 PM
1sickdc's Avatar
disconnect the ecu and remove all 4 spark plugs and crank it with no ecu connected or spark plugs, crank it 2 or 3 times to get the fuel out of the cylinders, after this reconnect your ecu and spark plugs, it should turn on i have the same issue right now im running 750 injectors untuned and the same thing happens to me
skwigelf
May 26, 2014 05:57 PM
sazdasl
17
May 15, 2007 06:51 PM
boostedcivichatchbacksi
Jul 22, 2004 02:29 PM
DJPAKMAN
Jun 13, 2004 11:44 PM
cr00klyn718
Jan 11, 2003 03:25 PM
