First swap, code 5, 14, and 41
Old Feb 25, 2006 | 02:25 PM
theneil's Avatar
Default First swap, code 5, 14, and 41
I have a B16A2 in a 92 CX hatch. I bought a 95 SI wiring harness to help make the wiring easier for me.
Currently throwing code 5, 14, and 41.
Code 5 = MAP sensor
Code 14 = Idle air control valve
Code 41 = Primary oxygen sensor heater
I could really use some help. Could it be the wiring? I thought the 95 Si harness was plug and play. I have searched the archives and can't make heads or tails of anything.
Any help or just links to where I can find some help would greatly be appreciated.
Also looking for a damper (crank pulley) I searched the archives and I was just looking for a reputable company. Thanks.
Modified by theneil at 8:19 PM 2/27/2006
Old Feb 26, 2006 | 06:31 PM
theneil's Avatar
Default Re: First swap, code 5, 14, and 41 (theneil)
tried a p75 ecu today, now I'm just throwing code 14
any thoughts?
Old Feb 27, 2006 | 05:39 AM
Jmunk's Avatar
Is the IACV plugged in ? Make sure that it's plugged into the right clip.
Old Feb 27, 2006 | 04:13 PM
theneil's Avatar
Default Re: (Jmunk)
yes, I believe they are both (the map sensor and IACV) plugged in correctly
Just to make sure I reversed the plugs and I'm throwing the same codes
hondachris1994
12
Aug 15, 2008 03:13 PM
gsr2envy
Nov 7, 2004 03:32 PM
