final drive??
Old Jun 18, 2002 | 03:04 PM
Dorikamu's Avatar
Default final drive??
can someone tell me what does the ATS final drive to the gear ratio... does it make very gear closer?
Old Jun 18, 2002 | 03:08 PM
Katman's Avatar
Default Re: final drive?? (chusai)
That is correct. And what the outcome of closer gearing is snappy acceleration.
Old Jun 18, 2002 | 05:22 PM
IN VTEC's Avatar
Gear spacing remains the same b/w gears.
Old Jun 18, 2002 | 06:45 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
No. The gear ratios stay the same. Final drive will collectively lower the speed that each gear takes you.
Old Jun 18, 2002 | 07:52 PM
Kamin's Avatar
https://honda-tech.com/zerothread?id=196655
and use the search button!
[Modified by KAMiN, 8:52 PM 6/18/2002]
Old Jun 18, 2002 | 09:51 PM
Dorikamu's Avatar
Default Re: final drive?? (ActiveAero Ninja Edition)
how does it drop speed on each gear with out affecting the gear ratio and how do this make faster acceleration?
Old Jun 19, 2002 | 12:57 AM
Rocket's Avatar
I agree with Katman. Just play Grand Turismo and you'll see what he's talking about.
Old Jun 19, 2002 | 06:29 AM
Dorikamu's Avatar
Default Re: final drive?? (Rocket)
I thought katman is rite too...
Old Jun 19, 2002 | 08:39 AM
Katman's Avatar
I believe what Mr. ActiveAero Ninja Edition is trying to say is that a final drive will affect the deceleration/acceleration rate (depending on the ratio used) of the car once each gear is filter through the final drive, to the axles, then to the wheels, then to what you feel, in yo' ***. The final drive is seperate from the 1-5 gears. The 1-5 gear's are in a sense 'filtered' through the final drive. I'm sure you know that already though.
The 4.9 FD for instance will increase acceleration & deceleration. By deceleration, lets say you're going at a steady 40mph and you let off the throttle while in gear, the car will on it's own, slow down faster (decelerate) than it would with your stock 4.40 fd. More teeth are on the 4.9 FD ring which in turn makes it a higher/tighter ratio or as some like to say, lower gear/ratio (meaning tighter). I use the terminology of 'higher ratio' because it makes more sense then 'lowered gearing'.
[Modified by Katman, 9:41 AM 6/19/2002]
Old Jun 20, 2002 | 09:04 AM
Dorikamu's Avatar
Default Re: final drive?? (Katman)
so the top speed of the vechicle stays the same with closer final drive?
Old Jun 20, 2002 | 11:09 AM
Katman's Avatar
heh, i left that info out.
No, the top speed will not be the same. The top speed will actually be hurting a bit with a tighter final drive. It's not that bad though as far as a 4.785 fd goes.. I've never experienced a 4.9 FD though. If the FD is longer such as an integra LS FD 4.266 you will have better top speeds, but your overall gearing will not have very tasty acceleration with an LS FD...
Old Jun 20, 2002 | 11:39 AM
Dorikamu's Avatar
thank you thank you
Midori Green
Apr 30, 2008 09:11 PM
5zigen_dc5
Mar 31, 2006 05:06 PM
RS_91
Aug 27, 2003 07:31 AM
slofu
Sep 4, 2002 02:05 PM
R2D2
Jun 17, 2002 07:40 AM
