fields vtec controller wiring ?
I looked here. http://asia.vtec.net/beystock/....html
My question is you electro-tap 2 wires (ignitor signal and rpm signal) What about the other 4 wires? Do I cut them and splice the harness side to 1 wire on the fields and splice the ecu side to the other side of the fields controller. Example (vtec signal) blue wire towards engine harness side and the yellow wire towards the ecu side?
thanks
thanks
Yes, Cut the wire in half and connect the corresponding wire from the fields unit to each end. I suggest soldering the wires if you can. If not, make sure your crimps are tight.
lightningd
Apr 4, 2003 01:30 PM
