fast help!! Dizzy bolts??
Old Nov 10, 2003 | 05:40 AM
T-Mo's Avatar
Default fast help!! Dizzy bolts??
Does anyone know the size of the distibutor bolts. Just found out that my dizzy is held on by only one bolt. It is leaking oil in that area. '92 Prelude Si. Honda doesn't have them in stock
Old Nov 10, 2003 | 09:04 AM
integra6650's Avatar
Default Re: fast help!! Dizzy bolts?? (T-Mo)
theyre all the same size so take the one good one somewhere i believe their m10x 1.25 by about 2 inches but dont quote that
Old Nov 10, 2003 | 11:10 AM
JimBlake's Avatar
Get a new seal, too. Even with only 1 bolt, the distributor probably mounts straight & fully inserted. So when you put the other bolts in, with the same old seal, it'll still leak.
Clean it up & make sure you know it's leaking from the distributor. Or maybe the valve cover gasket?
Old Nov 10, 2003 | 02:55 PM
T-Mo's Avatar
thanks folks. it was an 8x1.25 30mm screw. I already change cap &rotor button, and I put a new valve cover on. That's how I discovered I had only 1 dizzy bolt.
PuroMotor
Jan 9, 2014 12:46 PM
Cuong-nutz
Apr 13, 2005 09:39 PM
98R-1144
Jun 28, 2004 05:21 PM
T-Mo
Nov 10, 2003 06:16 PM
T-Mo
Sep 27, 2003 12:36 PM
