Fan stays on even on cold engine.
Old Oct 3, 2011 | 01:46 PM
sl33p's Avatar
Default Fan stays on even on cold engine.
I have a 1992 Prelude, H23A3, and after getting an engine swap done, if i turn my car off the fan will stay on. Even if it has been sitting in the garage for the whole day, if i turn it on just to move the car to the spot beside it, the fan will continue to stay on for 15 minutes. Previously, no fan would stay on, even in the blazing middle of summer after a 2 hour drive. I live in Ontario, Canada, and right now its pretty chilly at night as well.
I know its normal for the fan to sometimes turn on and stay on for 15 minutes but is it supposed to do that even if the engine is cold?
Old Oct 4, 2011 | 10:06 PM
streetplayas's Avatar
Default Re: Fan stays on even on cold engine.
no it shoudnt eitheir 2 problems faulty fan switch which is located on the thermostat housung or the relay is stuck in the open position if im not mitaken it located under the hood in the fuse box
Old Oct 5, 2011 | 01:33 AM
HondaPartsHero's Avatar
Technical Hero
I believe the prelude also uses a fan timer. Its probably a bad fan switch. Check here
http://techauto.awardspace.com/overheating.html
Old Oct 5, 2011 | 02:55 PM
sl33p's Avatar
That link is dead on, Thank you very much!
PhilipS
Honda Civic (2001 - 2005)
Jun 22, 2017 02:36 PM
zrsm9
Aug 13, 2010 08:13 AM
Paluce
Mar 20, 2007 09:33 AM
cslegacy
Jan 12, 2007 11:59 PM
KillerElfboy
Jun 22, 2006 07:26 PM
