falken azenis..
Old Oct 17, 2003 | 05:48 AM
MarkZeroNine's Avatar
Default falken azenis..
are the depth of these tires typically less than normal tires even when new?
Old Oct 17, 2003 | 11:01 AM
WuRKD b16's Avatar
Default Re: falken azenis.. (markzeronine)
depth? i dunno wat u talkin about. all i could say these tires are da bombs. THey good in handling cornering, good lauches, sticky as hell, and cheap for what u get. Def recommend these bad boys
Old Oct 17, 2003 | 12:41 PM
King Tut33's Avatar
If they are as sticky as everyone says, then I would say that the tread depth would probably be less than normal and they will wear out rather quickly.
Old Oct 17, 2003 | 01:02 PM
Audi RS4's Avatar
Lover
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by markzeronine &raquo;</TD></TR><TR><TD CLASS="quote">are the depth of these tires typically less than normal tires even when new? </TD></TR></TABLE>
explain further WTF you are talking about, depth??????? do you mean width?
Old Oct 17, 2003 | 01:04 PM
Default Re: falken azenis.. (AK1200)
no sry.., the deepness of the threads in the tires.
Old Oct 17, 2003 | 01:39 PM
King Tut33's Avatar
He means tread depth usually measured in 32nds. All tires come rated at a certain 32nds when they are new then you can use that to base what percentage of the tire is worn.
Old Oct 17, 2003 | 02:27 PM
LudemanDan's Avatar
Default Re: falken azenis.. (King Tut33)
Normal depth is 10 or 11 32nds. Azenis are 8 32nds. Yes, they are shallower. Too bad for such a soft tire, it would still handle great if it were a little taller!
Dan
ej6hatchie
Apr 14, 2008 04:22 PM
SFlCrx
Nov 4, 2007 12:08 PM
datssoled
Sep 12, 2007 12:35 PM
Curtisbeef
Aug 12, 2005 05:53 PM
mnbv
20
Jul 18, 2004 10:47 AM
