failed smog, need some suggestions
15mph
co2 02 hc(ppm)
meas meas max gp meas
13.10 1.90 134 308 241
c0 n0
max gp meas max gp meas results
.82 2.32 .85 847 2070 2552 gross pulluter
25mph
co2 02 hc(ppm)
13.90 1.40 108 20 122
c0 n0
.71 .09 .18 786 199 438 fail
setup is ls/vtec ~11.5:1 compression, ctr cams at 2, -1 dc 4-1 header and new cat, timing set at 9degrees, new oil etc. stock p28 program. fp at 41psi
i didnt think i would do that bad but next thing im gonna try is switchin to stock header, cams back to 0, 0, stock filter box. only thing i thought was weird was my results at 25mph dnt look that bad compared to 15 mph where it was more then twice as bad
[Modified by sparkz, 4:41 PM 3/12/2003]
co2 02 hc(ppm)
c0 n0
25mph
co2 02 hc(ppm)
c0 n0
do you have a working cat? if not, get one.
do you have your ecu chipped or have a motor swap? borrow a stock ecu for a couple hours
if not, get a tune up, replace spark plugs, retard the timing. that should get you to pass.
good luck.
good luck.
ok i think using a stock p28 ecu was a bad idea. i just compared the stock maps for p72 and p28 provided by hondata and in the areas between 2000-2600 rpms, the p28 runs slightly richer vs the p72 and timing is about 4 degrees higher in the same areas on the p28
highperboi
Jan 11, 2005 06:30 AM
